first 24 hours with it - two issues....
Skrems
Hi All,
Love the flight characteristics so far - fast when needed and silky smooth when in tripod mode.
Two issues though -
1) Really washed out video and pictures. I have left every thing as auto except switching to Sunny once for WB. I get the zebra stripes almost everywhere there is a light area. I know I can manually override this (change ISO to 100 etc) but I was hoping out of the box auto would give me 'good enough' results. The color profile is set to Natural. Do you think there is a sensor issue or did I overlook something? I see on the forum here there are several settings for best video but those are all manual.
2) The bloody craft keep saying there was an obstacle in front but I was at 300 ft and not facing the sun. I also see in the forums about this issue but it seems to be only when facing the sun and the plastic labels left on. Neither of these apply. I can live with this and turn it off if needed.
Cheers!
Steve
Leaving everything in auto, do you see an EV rating on the screen saying +1 or higher? That's an exposure value you can adjust with the right RC wheel. Bring it down to 0.0 or even -0.3. The setting is there even in auto, to let you compensate for snowy scenes or deep sunsets which should not be mid-tone, but maybe got dialed up accidentally.
Reactions: Skrems
For 1) Turn down the EV using the right hand upper wheel until you have a 0 EV.
For 2) Check that the sensor windows are clean, have no clear stickers attached. A forward sensor calibration might be in order.
Reactions: Skrems
Polarizing ND filters make the image WAY better, highly recommended. More color and saturation.
Also what everyone else is saying turn the EV down a notch or two (E V is Exposure Value compensation).
Reactions: Skrems
ahhh yes! It was showing +2.3 now. I have set it to 0 and will try again tomorrow in the same light conditions. Cheers!
Thanks on both - The forward sensors are sticker free and clean. I will try the calibration. Cheers.
OK yeah that must have been it. The ND filters from DJI were back ordered. I think I will get them from amazon. Thanks.
Wow, yeah +2.3.... out of a possible +3 is VERY bright, no wonder it was totally blown out. I'm sure you will have much better results :-)
The front sensor calibration requires that one install the DJI Assistant 2 software and plug in a usb cable to the side port on the Mavic Pro.
Yes - the dial was causing the over exposed video. Perfect now!
Thanks all.
No members online now.
captainscottyy
