Hey guys, I'm not worried at all, more curious as to why the rc icon flashes even at full signal strength. Anyone who might happen to know the answer?
That makes sense. Phone was in flight mode. However I had my SmartWatch on.
Thanks for your reply [emoji3]
What do you mean when you say make some changes?If you are flying in a new location it could also be that. A way of testing this is when it happens brig the mavic back and land then restart the Mavic and RC after make some changes.
Everything you say makes perfect sense. I sometimes fly from my back garden where I'm surrounded by wifi. I notice it happens there also
To be honest I've flown big distance whilst it's been flashing. But I wouldn't say it has an effect on range or signal. Have you had any problems with those things whilst flying?I get this often when flying in one of the locations I go to ... it does not prevent me from flying it just comes and goes just keep your flight range short when you know it is happening.
No this has never impacted range at all for me, I have just taken a bit more care with my flight plan and switched the RTH to hover just incase.To be honest I've flown big distance whilst it's been flashing. But I wouldn't say it has an effect on range or signal. Have you had any problems with those things whilst flying?
I always set RTH to return home, if signal gets completely lost and your craft is set to hover you may have an issue retrieving the connection again.No this has never impacted range at all for me, I have just taken a bit more care with my flight plan and switched the RTH to hover just incase.
I'm more partial to long range flying though so itmay not particularly apply to you if you keep your aircraft relatively close by.
Yes that's definitely the best option. Something I never really thought about actually. I don't fly underneath anything in general. But definitely a good point incase I ever doThis always depends on the flying location and weather conditions so I change it based on this ... if I am flying uner something then signal lost RTH is always set to hover as it would crash otherwise but in open ground and flying at distance I set RTH to come home.
