flight records - smart controller
Hobart, Tasmania. Australia.
I have 164 flights recorded and wondering about how to " save" or store this flight data? Do you copy them off the smart controller and save them somewhere else to view and learn from? Is there a way to store them for Mac users?
When I play the flight data, I get the coordinates and the flight line the drone flew; but the map does not come up with any detail and says " map loading". Is there a place to download these flight records that would also give me proper map detail?
The map detail is not in the logs. Basically the GPS coordinates are read from the logs and map data dynamically fetched from the internet.
I seem to recall someone having wrote a stand-alone flight log player.
The logs are the TXT files that those here ask for when analyzing flight problems. You can sync all your logs to DJI, which is bi-directional. If you set it to keep all logs, then when you fly with one device and sync, when you sync on another device, the flight from the first device will appear.
To find your flight records, start your SC click the app icon
Then the File Manager icon
For manual removal/storage, use a USB cable to retrieve the internal storage or an SD card reader to remove the external files to your computer.
Your files are located as below, depending on whether you have them going to the SC's internal storage or to an SD card.
internal storage DJI/dji.go.v4/FlightRecord
external_sd DJI/dji.go.v4/FlightRecord
and will look like this:
internal storage DJI/dji.go.v4/FlightRecord/MCDatFlightRecords
external_sd DJI/dji.go.v4/FlightRecord/MCDatFlightRecords
This is all a manual process and there are other ways to move and view your flight records that are more automated. But if find this method simple and quick. I can then upload them to one of several different viewers/storage sites (see @msinger's MavicHelp).
Reactions: globetrotterdrone
SkyPatroller
