Fly App 1.1.6 update on the yaw smoothness glitch!
J.C.
Canada
I did test both platform Android and IOS and they behave the same. I am waiting on DJI to come back to me with an answer if this is a glitch or normal!
Hello this is an update to the yaw smoothness not working.... I did few test with Android and IOS phones and when APAS is switch to on position you cannot change the yaw smoothness even is you play with the slider in the app. When you switch APAS off then you are able to vary the yaw smoothness in normal mode ....sport and tripod mode are not affected they work even if APAS is on or off. I find this bizarre that you can't change the yaw smoothness when APAS IS ON with normal mode ..... Don't you?
I just did a bit of testing with the new firmware and it looks like the smoothness settings work if the obstacle avoidance is set to "brake" or off, but don't apply when its set to "go around or avoid". Only Normal mode has this option, in Tripod mode it's just set to brake, and Sports mode doesn't have O/A at all.
Tripod mode doesn’t have APAS, that’s why you only get the Brake option
tflys78
