I'm getting ready to purchase a M2P, and trying to decide which way to go with accessories, etc....
- want to have a handful of extra batteries
- I'll be using this out on the water (off a boat) from time to time to capture footage of some fishing, etc - would like to be able to recharge batteries while on the water - have numerous 12V AGM Deep Cycle batteries - one 36V bank available
- want at least one set of spare props
- I'll want to get a good set of ND filters
- ill want a hard-case, but also something more compact (soft-case) to use at times.
Trying to decide if I should go with the FlyMor combo, but given the DJI "car charger" requires 13.6V to charge, this won't help me on the boat unless the big motor is running (which it is not 95% of the time I'm on the water). So, I'm trying to get pointed to the best solution for charging - both DC-based and AC-mains (US) based
Seeing mixed reviews on the parallel AC charger from FPV or other..... but its hard to tell what is old reviews on older versions, etc.
So - those of you that have been through this, please point me in the right direction
- should I piece-meal a kit together with the parallel charger, 3rd-party "car" charger that can accept <12V input), etc?
- should I get a DC-to-DC voltage converter ($20-$40) and go with the DJI car charger
- what's the best parallel charging unit currently
thanks!
thanks!
