Forgot to record
Levoqd
I always forget to record or hit the record button by accident and stop recording without knowing. Any tricks?
I verify my recording status by checking the record time counter.
I start recording before I take off; it is my final checklist item. I have a large enough memory card in there so I am not worried about running out of space. You can always throw away a recording if you don't want to keep it.
a man after my own heart press record focus slide the take off bar and away you go
Start recording before you take-off as part of the pre-take-off checks. Record everything ... Then at the end of the day, use your video editing software to make the video you want to keep.
If you start recording at take-off, make sure to check the focus at altitude.
Reactions: FoxhallGH
when you focus before take off the camera will be focused at the distance of the nearest object in its view so as you go higher things out side of that range will be blurred if you touch the screen to focus box any time during flight then you will correct this,i have chosen the left hand button on the back of the controller as my focus button saves touching the screen
Or my Inspire1 I guess. I think the problem might be that I get a warning box on my screen every time I fly (I am in Class D airspace, but have a COA and a custom unlock from DJI). But every time I fly I get a red box that warns me that my RTH route will go through a no fly area and may not work. I have to touch the screen to get rid of it, and I wonder if that also affects the focus, because I typically don’t start recording until I’m at 20 or 30 feet. I might have guessed that I was close to a tree (as I’m looking down the fairway) but even the nearby trees are not in focus. I’ll do some more testing.
I found it frustrating when using the shutter buttons on the SC that the first click of the “other” shutter button only switches the mode from video to still or vice versa , but doesn’t activate the shutter. I’ve missed some pictures this way. Live and learn.
I do this too and as a newbie have missed some awesome footage I thought I was recording :( Some great ideas here thanks
Reactions: zzxrox
What's strange for me is that I have been very good about remembering to start recording before take off (and I'm getting better at remembering to focus in the air), BUT, I have lost count of the times that I think I am taking a video with my iPhone, I then press the red button to stop when I'm done, and it STARTS recording. It's tough to say to your daughters 8th grade band during a concert "That sounded great, but could you please play the song again so your drummer's father can record it this time." (This has occurred at concerts and wrestling meets........)
Peter T
Maybe say “the clarinetist’s father” and give your kid a break! But hard to ask the wrestlers for a redo...
Reactions: Mossiback
gonzoales
