Forward Vision Sensor Problem After Replacement
hometheaterman
So, after a crash which resulted in both forward Vision Sensor wires being ripped, I replaced the sensors as well as the gimbal main board they hook to. Upon turning on the drone the app gives me an error telling me they are abnormal and it asks me to calibrate them. The calibration fails every time. However, the sensors seem to read accurately, the drone just doesn't stop like it should. Has anyone run into this? Any idea what could be wrong?
...The calibration fails every time...
I can't help with the rest, but I have read about calibrations failing on one computer monitor and passing using another.
Did you remove the plastic covering the sensors?
The calibration needs a specific monitor resolution, if it is too high or low it will fail.
As stated above ~ I tried calibrating VPS on two desktop computers, running 1920x1200 screens with no joy. It was my laptop @ 1600x900 that saved the day.
Espletico
