Fully charged battery voltages
Heisenberg
Spain
Hi everyone!
I have my Mavic since a couple of weeks. I've noticed that the voltage per cell in a fully charged battery is always around 4.26V in DJI GO 4. Last day I charged using the car portable charger, used the battery right after charge ended...and voltages were around 4.28V!
Are these values ok? I have many other LiPo batteries for RC helis and planes and I never go beyond 4.20 V/cell.
Thanks in advance.
Hello Heisenberg
You say that you charge your batteries to a cell voltage averaging 4.26V, a voltage at which you are not concerned, so to put it in perspective 4.28 volts is only 1.9% higher than the 4.20v you charge your other Lipo's to, and 4.28v is only 0.47% above the 4.26v that you are used to, I would not be unduly concerneed by this...
Waylander
Yep that's normal. The mavic uses HV lipo batteries, a fully charged battery with no load will be 4.35v per cell. Once you turn the Mavic on it will drop to 4.28-4.29.
Thanks to both for your answers! I wasn't aware that the Mavic batteries were HV LiPos o_O Now all the voltages per cell make perfect sense!
Hi everyone!
Thanks in advance.
The others gave you the green light. Made me want to know more and I found this article.
Mamanov Ramazan
