G'day from Australia.
AussieKev
Marulan NSW
I'm not a big forum guy but after a hard crash which left me with a broken RHS front arm on my DJI mini 4 pro I thought I'd better pick the brains of guys much smarter than myself in the hope that I'll learn where to buy the replacement part. YouTube has been a great source of information but it falls short on some things. Now I'm off to try and work out how this site is laid out and navigate my way through it without making myself look too much of a dope.
As you can see, this site has many specialized areas: Subjects (News, Control Apps, Photos, etc…), Models (Mavic Air series, Mavic Mini series), Locations (countires, cities, etc…).
And if you ask any member, they will you where to go… L 😁 L . . .
As the old expression goes, "Give an Aussie a fish and you feed him for a day, but teach him to fish, he start a new "Fish & Chips" franchise…" L 😂 L . . .
Since you live in Australia, there are specific laws and rules for you to follow, please check to ensure these are current.
Plug in your phone/tablet into your controller; turn on the Controller and DJI Fly App (if it does not start on its own…). On the Drone, open the front legs, then open the back legs, and then remove the Gimbal Cover.
Lift off, 6 feet (2-meters) or so, hover a bit, check the controls (move the drone a bit forward, back, left, right, yaw left and right). By now, your Controller will probably report again, "Home point Updated."
Below is the link to all of the downloads offered by DJI for the Mini 4 Pro, including the User Manual.
Fly On and Fly Safe…
Welcome to the forum from the beautiful woods of Maine, USA!
There’s many knowledgeable members willing to help you with any questions you might have. Search the forum using keywords and if you don’t find any answers, post your questions and I’m sure you’ll get a quick response!
Fly safe, enjoy and stay safe!
@LoudThunder
"And if you ask any member, they will you where to go… L 😁 L . . ." :rolleyes:
@AussieKev
"myself look too much of a dope." :rolleyes:
Monkey see, monkey due or do? :)👌
This forum is way different, there is more than me and LT. that have a twisted humor. Thumbswayup
I actually made a friend on these forums in Australia, we pass stuff back and forth a lot using signal.
Almost forgot. :rolleyes:
Welcome to the forum!
Rod ..
Welcome to the forum @AussieKev! :)
Thanks Mate, I had a crack at repairing the broken front arm on my mini 4 pro. I used super glue and baking powder and I think its as strong as it ever was. The hard bit was fixing the drone down onto a solid board and then align the broken arm in the right position and then start the repair. Once finished and a little bit of sanding I was impressed with the outcome and the thing flies as good as new. Happy days again lol.
tagir
