Just purchased a M2 zoom.
mavicpilots.com
Since you live in Australia, there are specific laws and rules for you to follow, please check to ensure these are current.
Australia’s recreational drone rules are designed to keep you and others safe, on the ground and in the air. Here are the rules you need to know now, before you take-off.
www.casa.gov.au
Plug in your phone/tablet into your controller; turn on the Controller and DJI Fly App (if it does not start on its own…). On the Drone, open the front legs, then open the back legs, and then remove the Gimbal Cover.
Lift off, 6 feet (2-meters) or so, hover a bit, check the controls (move the drone a bit forward, back, left, right, yaw left and right). By now, your Controller will probably report again, "Home point Updated."
Below is the link to all of the downloads offered by DJI for the
Mavic 2, but I do not which covers the "Zoom", including the User Manual.
Learn and download
Mavic 2 related apps, software, and manuals at the DJI Download Center
www.dji.com
Learn and download
Mavic 2 Enterprise Series related apps, software, and manuals at the DJI Download Center
www.dji.com
Learn and download
Mavic 2 Enterprise Advanced related apps, software, and manuals at the DJI Download Center
www.dji.com
Fly On and Fly Safe…
