Gimbal Error 40002 - but Movement during startup is normal
Henfri
Hi,
the Gimbal moves normally during Startup-Sequence. However, in the app the Gimbal-Stuck message pops up.
Also, when flying, the Video is shaky. When moving the Mini on ground, the gimbal does not seem to stabilze. It remains fixed relative to the drone.
Up to now, I:
- refreshed the firmware
- made sure that there is no physical obstruction (switched drone off and moved gimbal carefully in all directions
What's next? Is there any way to check, whether it is the gimbal motor or gimbal IMU?
And what is the possible fix? Ribbon Cable?
Greetings,
Hendrik
Reactions: Cafguy
You should first try to blow out any Dust....... NO CANS!! Blow it out Gently. Did you use a can of air? Secondly did you work on or replace the gimbal? A bad cable or connection will give that error.
Buldre
