Gimbal not Connected
tapiap
Problem? I have a Mavic PRO Platinum which I have barely used 3 times for less than 30 minutes total. I can not get it to fly -- RC does not seem to connect to drone. It says "Gimbal not connect.
The unit has never been in any type of crash. I called support they had me link the unit, and that did not work. I also loaded the latest version of software and that also did not work. I pulled out the memory card, given someone reported a problem with the SD card, same results.
I'm using an iphone with the APP, in addition to a SAMSUNG tablet... same issue.
What firmware are you running ( aircraft, remote controller)?
I don't know what software version I'm running on the RC... I loaded the latest firmware using the DJI assistant app , but don't know how to upgrade the RC. The GO APP version is v4.3.0 ...
I have made no other changes...
I basically don't think the RC and the APP on the device are communicating, and I'm beginning to suspect the port on the RC where the iphone connects.
any help would be appreciated.... thanks
Overspeed
