- Joined
- Apr 17, 2018
- Messages
- 12
- Reactions
- 0
- Age
- 31
You say no crash. Hard landing?
Check that your gimbal is mounted correctly, there are many videos that show how it should look. The GPS warning would be a separate issue. With multiple warnings like this, perhaps firmware a reload is in order?
When you turn on the Mavic the gimbal motors cycle through their full motion range. Is the gumball hitting or hanging up on anything? Is there a lens filter not fully pressed on?
I'm betting that your gimbal is not properly mounted under the three tabs. Most likely the back one, because people don't know about that one. It will sometimes work, other times it will give an error
Can you explain how to do it? maybe with a video. thank you so much
