When I replace my ribbon, do I need to put a dab of silicone back on them??? If so, is there a specific type I should use?
Where dji has it on the plugs for the ribbon cables. Had to pull some off to get the cables off, wasnt sure if I needed to replace itOP, I would not use anything on the ribbon, no need to if you do it right. Where are you thinking about using silicone?
I'll just leave it be lolIf you can apply it without getting any on to the pins, or inside the connector, you can try it. Next time you try to get the connector out, it might be tough.
