Gimbal (slew) camera left and right
Berf
USA
Is there a way to slew the camera left or right on the Air2s when the drone is stationary?
Most drones don't let the user rotate the gimbal about its yaw axis. You'd have to turn the entire drone itself to get the shot you want.
Yes , you should be able to pan the camera with your finger across the screen or just move the gimbal if that is what you are referring to with the drone not at idle.
Phantomrain.org
Gear to fly in the Rain. Land on the Water
On my M2Z I just touch the screen and drag left or right. I should also say holding your finger on the screen controls the gimbal in all directions. Just make sure you center it when ready to fly off.
Reactions: Dbez1
You don't have a control to move the yaw axis of a gimbal but if it's like the Mavic 2 Pro, you just touch the viewing screen, SC or phone and while keeping your finger there, slide along the surface either left or right and the gimbal and camera will follow that sliding movement.
keem21
