Gimbal Stuck
Night Flyer
Virginia
Well not really but that's what the display is saying after I was set to fly. Cut off the controller a few times along with the drone and finally it was able to fly. As a new drone owner I'm not sure I dd anything wrong but it was fine this morning.
Are you certain that there was nothing in the way when you powered on the drone The gimble is pretty finicky when it first initializes even the slightest debris will trigger that warning However if the gimble was clear and you are getting the warning I would contact DJI
If it happens again I'll contact DJI, thanks.
I have seen people put there drone in the case way to tight and have that issue warning for a few seconds after starting .
Are you putting it away in a case >?
Phantomrain.org
Gear to fly in the Rain. Land on the Water
BausInGV
