Gimble
rudeboy1063
Do i have to clamp the gimble down on back bracket and the 2 front brackets before flight cheers for any help in advance cheers robbie
The back bracket under the gimble
You shouldn't have to adjust anything before flying. Did you crash and/or break something?
Iv just seen the dji tutorial it's says it before flight I might of said it wrong msinger
No I haven't flown it yet just want to get things right so I don't crash only got it before done the firmware and battery's
Take a look at the videos and if your gimbal is below the three tabs (two in front, one in back) you should be fine, I think sometimes they have popped out during transport but you should be fine.
Regards,
-d.
You should remove the gimbal lock before powering on your Mavic. Most people remove the dome before flying too.
YT360
