Glitches
kenzero7
What do you guys think? Do I need to send it for repair? Check out the glitches at 0.07s and 0.09s
i am not sure they are glitches more like bees
Reactions: kenzero7
Given that there's sound and it's only 720p I'm pretty sure that's a local copy from your phone which can be pretty glitchy depending on your signal quality.. check the video on the onboard SD, that's what matters
Reactions: kenzero7
I watched the original video in 4k, its the same as that, only in 4k and no sound so I didn't bother uploading it.
Lose the bubble!
Have you been able to replicate this problem? You'll only know for sure that you indeed have a problem if it occurs constantly, or at least intermittently. At the very least, remove the bubble. It catches back light and reflects it onto the lens, which may be the only problem here.
Reactions: kenzero7
Reactions: Qoncussion
hughesthis
