Good morning from the South Carolina Lowcountry
Jeffythequick
Mt Pleasant, SC
Howdy everyone,
I got a Marvic Mini 3 which I exchanged for a Mavic Mini 4 Pro, just because I want a drone to follow me and have the benefits of the “pro” line. I am a Part 107 pilot, a private pilot (of the ride inside aircraft), and I have some experience with the FPV drones as well. Oh yeah, that’s another reason for the Mini 4 Pro: I eventually want to get an Avata and hook the Goggles 2 to the Mavic 4 Pro.
One thing that has always made me wonder about flying FPV: Why do I need a spotter? When I’m flying a “real” airplane, I do it FPV, because I’m in it. I don’t have someone on the ground telling me to watch out for things. FPV is the most aware I can be while flying. Oh well, rant off…. I know I can turn my head in the airplane.
Drone List:
DJI Mavic 4 Pro
DJI FPV
DJI Mavic 1
Rekon 7 7in FPV drone
AOS RC 7 (7in FPV drone)
Have a great one!
Jeffy
@Jeffythequick firstly welcome to the forum
with regards to you question about a spotter ,if flying with goggles on ,all i can say is what kind of pilot are you ,(it should be fairly obvious why you need a spotter)
sorry if my post offends you
Hello from the Crossroads of America Jeffythequick.
Nice to meet you Jeffy. 🤝
Welcome to the Forum. :cool:
Howdy everyone,
Drone List:
DJI Mavic 4 Pro
DJI FPV
DJI Mavic 1
Welcome!!
I am a Part 107 pilot, a private pilot (of the ride inside aircraft), and I have some experience with the FPV drones as well. . . . One thing that has always made me wonder about flying FPV:
Since you live in South Carolina, there are specific laws and rules for you to follow, please check the link below for all the Rules and Laws that are in effect in your neck of the woods and it also links you to some of the Best Places to Fly in your area… Also, if you travel on vacation, visit friends, and relatives in other parts of the country, check back here so you do not run afoul of the law.
Since there is no "Driver's Exam" to get at Part 107, you did not mention your experience, rbrn though you have a stable of drones...
As for your question of why you need a spotter when flying FPV and considering you are a pilot, bothers me…
When was the last time you flew your plane down the sidewalk at only a few feet off the ground at 50-plus MPH with pedestrians all around you, or zipped through a park or along a beach with sunbathers??? When you are flying an aircraft, you are moving in a straight line, relatively speaking, and you can look all around from your single seat. When flying FPV, you can only see what is in front of you and you only know what is to your side when you fly into it because you did not see it until you turned. Next, imagine you are flying your plane and some solo FPV'er with no spotter is zooming around without a care in the world what else in in the air…
I am guessing that you acquired your part 107 through self-study rather than an established commercial training course, because this subject of a spotter is covered extensively…
So, that is all I'll rant on this subject, and if you are still not convinced that having a spotter, whether you are PFV'ing, flying commercially, or just joy flying, is a "Why do you need a spotter?" then I suggest you search out database on the subject or even open a topic in the General Discussions Sub Forum…
Moving on, you paid a lot of money for that Drone, put your phone number on it. If your drone gets lost or stuck in a tree and it finally comes down when you are not around, give the finders an opportunity to contact you so it can be returned.
Lift off, 6- feet (2-meters) or so, hover a bit, check the controls (move the drone a bit forward, back, left, right, yaw left and right). By now, your Controller will probably report again, Home point Updated.
Fly On and Fly Safe…
paul44509
