Google Earth Pro Terrain question
joeruby
Glendale, Arizona
I have been using Google Earth Pro (with terrain on, checked) to plan some of my Litchi missions. Recently I noticed that in some areas the terrain data no longer works for me, Please check out this test and see if you have the same problem. If so, can you explain what I can do about it.
Here is an example:
Bring up Google Earth Pro on a windows PC
Make sure the terrain layer is on (checked)
Search for "New River School, Az." (This has nothing to do with the school)
Does the area below the school look very fuzzy to you? This fuzzy area is very large (many miles!)
Missions that I planned several months ago, in these fuzzy areas, now fly underground when analyzed.
If you confirm this, can you suggest how to fix this problem or is this a Google problem, or a National security problem?
Again I am using Google Earth Pro to plan way-point missions in these areas.
Thank you,
Wow! yours is working OK. I have attached what I see here in Phoenix, Az. and also what a friend of mine in Prescott, Az sees. What could be wrong. I have completely uninstalled and reinstalled Google Earth Pro on two different computers. See attachment.
well I have this problem also and I can't find 3d buildings any help
Never mind I found it
but know I wonder why it does that ?
Reactions: DoomMeister
Here is an example:
Thank you,
Google Earth came up for me with Feb 2024 imagery. I turned on Historical imagery and found that the March 2022 imagery is much sharper. See examples.
FWIW, I do some mapping for my RV park, which is a Co-op. I flew a Dronelink mapping mission with my Mini-II and made an orthophoto and KMZ with WebODM.
2" pixels!
marcusjohn3684
