Recently baught a mavic pro at Walmart and didnt have to install the internal sd card to downgrade the fw to .700... anyone else have this happen?
Must be old stock, somewhere here you can see when it was made. Do a searchRecently baught a mavic pro at Walmart and didnt have to install the internal sd card to downgrade the fw to .700... anyone else have this happen?
On a newer mavic pro yes you do, if want to go back to a firmware you hack.Yes, you do not need to install SD card to downgrade or upgrade the firmware. SD card used for storage of photos and videos. Hope that helps.
If manufactured before Sep-19-2017 there will already be an SD card installed.Recently baught a mavic pro at Walmart and didnt have to install the internal sd card to downgrade the fw to .700... anyone else have this happen?
Was or is there anything to be concerned about these earlier models?If manufactured before Sep-19-2017 there will already be an SD card installed.
No. You can decode the serial number HERE.Was or is there anything to be concerned about these earlier models?
Hmm says 1 September 2017.. guess it sat at Walmart for 2 years. Thanks for the link... I tried other links for this, but got the dreaded 404 messageNo. You can decode the serial number HERE.
Use DumLdore to downgrade, works great!On a newer mavic pro yes you do, if want to go back to a firmware you hack.
Me too one I bought was mfg 1-17, I totally forgot about that issueRecently baught a mavic pro at Walmart and didnt have to install the internal sd card to downgrade the fw to .700... anyone else have this happen?
