Green Light turned off?
theharmonperspective
Just realized today that my green light on back of magic air is not coming on at all? Was I dreaming before when I thought it was always on when flying? If not how do I get back on
You were not dreaming it does flash slowly green when flying. I don’t think you can manually turn it off or on. When you first turn it on is it Red.
I heard of someone else having this problem on the DJI forum he had to refresh his firmware on DJI assistant 2
You can turn it off. It's under the settings tab for your photo or video. Cant remember off top of my head but it's there. My back light just blinked yellow for warm up then stay off for the entire flight.
Another thing. Once you turn it back on, mine didn't immediately start blinking again, I had to turn the MA off then back on. It then started flashing all colors again.
If you ever want it off again, easy: electrical tape.
Smart arm LEDs > status LEDs auto turn off
I've read it's a bug... I had it happen to me. It happened after i set the "Fn" button to toggle the front lights on/off. Just go in to the setting posted above and cycle it on/off again, that should get it blinking again.
Thanks guys that work. this is exactly when it stopped working! Appreciate all the help... knew i wasnt dreaming!!
Thank you on the status light problem. I also turned off my status light by turning off the red arm lights
with the Fm switch. I would of NEVER figured it out without this forum.
GLobus55
