Greeting from Speyer, DE
fzahn
Speyer, Deutschland
Hello everybody,
as a new member of this forum I want to give some introduction about my self:
I am 42 years old and am located in Speyer, Germany.
I started flying drones with a self-build hexacopter and a quadrocopter in 2014 using the DJI Naza M V2.
The hexacopter was equipped with a gimbal for a Gopro Hero 3 Black.
In the last years I did not really spend time for the drones, as I spend most of my time flying no-unmanned aircraft. I was attending flight school to get my PPL(A) and spend now most of my spare time on the local airport in a flying club.
However, I decided to start flying drones again and bought a Mavic 3. Its just amazing, how technology has changed since 2014 compared to my homebuild-drone:
1080p changed to 5.1k, live-view of the video is standard, 10minutes of fligttime with heavy 4S/5000mAh lipos has changed to 40 minutes with smaller DJI-batteries...
VIdeoquality has improved a lot beside the higher resolution.
So... here I am again.
Regards,
Florian
Welcome to the forum! :)
Welcome to the forum.
Please and do be sure you have read our guidelines.
Don't be shy and ask anything if you can't find it by searching . Thumbswayup
Hello everybody,
Regards,
Florian
Greetings from Colorado, USA 🇺🇸. WELCOME TO THE FORUM🎄
Greetings from Birmingham Alabama USA, welcome to the forum!
Since you live in Germany, there are specific laws and rules for you to follow, and they may have changed since you last flew… please check to ensure these are current
Even if you may have flown Drones before, and you once again new to Drones, here is some Good Old Fashion Advice…
Below is the link to all of the downloads offered by DJI for the Mavic 3, including the User Manual.
Happy Droning…
RobertCNewman
