Greetings from Canada
cmombo1652
Ottawa, Ontario, Canada
I’m an old guy with an old drone but am new to flying. I recently picked up an old DJI Mavic Mini and am having a great time with aerial photography and videography. It’s nice addition to my dabbling with amateur photography.
I’ll be moving from Ottawa to Alberta in the fall and am considering treating myself to a new drone - maybe a Mini 5 Pro or Air 4 (if they get released this year).
I hate you!!! Both of those drones, the Mini 4 Pro and/or 5 Pro are not and may not ever be available here again in the US… L 😂 L . . .
Since you live in Canada, there are specific laws and rules for you to follow, please check to ensure these are current.
Plug in your phone/tablet into your controller; turn on the Controller and DJI Fly App (if it does not start on its own…). On the Drone, open the front legs, then open the back legs, and then remove the Gimbal Cover.
Lift off, 6 feet (2-meters) or so, hover a bit, check the controls (move the drone a bit forward, back, left, right, yaw left and right). By now, your Controller will probably report again, "Home point Updated."
Below is the link to all of the downloads offered by DJI for the Mini, including the User Manual.
Fly On and Fly Safe…
aquamusic
