Greetings new friends! (Oklahoma)
Welcome to the forum from Ocean Isle beach , North Carolina. Congratulation on passing your 107 exam. What could be better than flying your done and getting paid for it. Not much. Good luck on your new career.
Blue skies
Safe flying
Congratulations on getting your Part 107 Certification...
As a New Drone Pilot, there are a couple of Legal Things you may need to do…
Your Drones no matter what their weight is, if you use them for anything other than fun, must be registered.
Since you live in Oklahoma, there are specific laws and rules for you to follow, please check the link below for all the Rules and Laws that are in effect in your neck of the woods and it also links you to some of the Best Places to Fly in your area… Also, if you travel on vacation, visit friends, and relatives in other parts of the country, check back here so you do not run afoul of the law.
You paid a lot of money for that Drones, put your phone number on them. If your drones gets lost or stuck in a tree and it finally comes down when you are not around, give the finders an opportunity to contact you so they can be returned.
Lift off, 6- feet (2-meters) or so, hover a bit, check the controls (move the drone a bit forward, back, left, right, yaw left and right). By now, your Controller will probably report again, Home point Updated.
Fly On and Fly Safe…
That was the best and clearest advice I've gotten since I've got myself into this, thank you so much! I registered Tweety Bird and Kermit when I had them in hand, and then went right over to amazon and got the stickers with my phone number and their FAA registration numbers. I put them on both sides.
I'm still at the so slow I could probably climb my butt on the roof and get photos faster. It's more fun for me to fly over the pasture and "spy" on the horses. Of the 5, only 1 doesn't like the drone, or rather he was the only one that noticed it. I'm not confident enough to fly over the pond at all, there is no way I'm fishing it out if it does drop itself in the drink. The snakes and turtles could keep it. LOL We have a lot of electric lines here at the house, literally on 3 sides of the house, so I have only flown it once here. Carefully, and keeping as far away from those lines as possible. I kept moving so I could see exactly where the drone was in relation to the lines to make sure I was not close. I'm going to have to go to my brothers farm and play down there, we can check the cows with the drones, that could be fun and there are a lot less power lines.
Here I thought the hardest part was going to be passing the 107, sectional charts are easy compared to avoiding trees and power lines.
Hungvth5911
