Hacking the Heat of the Mini 3 an Mini 4 Pro by Phantomrain.org
Phantomrain.org
Approved Vendor
As the Heat Index continues to climb so do the number of threads about these two drones overheating because they offer no internal fan .
DJI took a very aggressive approach to protecting the Battery from the rain by keeping these vents so tight, thus causing the drone to overheat so easily as well as not having the Internal fan.
So I created a small hack with the Wet Suit to increase the AIr Flow and Release of air allowing for flying in warmer weather.
The first hack is to drill 3 small holes across those black vents, to open them up, to allow better Air Flow in and out.
Next, we use the Wet Suit to create more airflow and also seal the vents when flying in the rain. .
These two changes increase the state of delivery of the Air Flow of this drone, allowing it fo fly in Warmer Weather,
Both the Mini 3 Wet Suit and the Hack work Seamlessly together and will be ready after the Holiday
I will post more pictures and videos soon, .
Phantomrain.org
Gear to fly in the Rain. Land on the Water and fly in extreme temps .
nikt_elo
