Happy New Year from Ontario, Canada!
Herongate
Ontario, Canada
Hi all,
i am a new drone owner and pilot (or wannabe pilot)! I bought a DJI mini 4 pro a few weeks ago and I am slowly getting used to flying it. I am concentrating on photography right now because that is my passion. I do wildlife, nature and macro photography as a serious hobby. But with time, I will learn to do video.
i love this community who has already been very helpful to me. Happy New Year to you all!
Since you live in Canada, there are specific laws and rules for you to follow, please check to ensure these are current.
Plug in your phone/tablet into your controller; turn on the Controller and DJI Fly App (if it does not start on its own…). On the Drone, open the front legs, then open the back legs, and then remove the Gimbal Cover.
Lift off, 6 feet (2-meters) or so, hover a bit, check the controls (move the drone a bit forward, back, left, right, yaw left and right). By now, your Controller will probably report again, "Home point Updated."
Below is the link to all of the downloads offered by DJI for the Mini 4 Pro, including the User Manual.
Fly On and Fly Safe…
Great advice LoudThunder! I really appreciate it! Happy New Year.
Reactions: LoudThunder
Welcome to the forum! :)
Happy New Year.
Same to you, Happy New Year! Just remember, A New Year's resolution is something that goes in one year and out the other. L :D L . . .
Check out the NRC site selection tool:
Set it to microdrone and it will show you the restrictions on where you can fly. The Ottawa area has quite a few. Note that there are other restrictions not noted in the NRC tool, because they are provincial or municipal.
You might also want to check out the Drone Pilot Association of Canada:
In terms of Canadian issues I like Don Joyce's Youtube channel "Don Drones On":
For advice on filming better videos I've found Stewart & Alina very useful:
Thank you very much Robert for the tips and links.
djimini3
