Has any one seen this ??
No. That is interesting - hanging out to watch the result!
Looks like an airspace restriction notice, I fly around airports all the time and get similar warnings, don’t forget climb corridors can extend a long way along the extended centreline of many airports.
It does sound like a DJI GeoFEnce restriction but it shouldn't be an issue because we ALL fly at or below 400' AGL anyway :)
What area was this in? Have you looked at any FAA maps to determine Airspace issues? It may or may NOT have anything to do with legitimate FAA Airspace but you'll want to check and confirm that.
Restricted to 492ft sounds strange. Altitude restrictions are usually 400ft or something like 200ft, and based on FAA facilities map.
If you look at the map in the DJI app, it should show the zone you are in.
I did check a few apps. They all said ok to fly. I was at least 10 miles away from the airport. The drone flew find even at 400ft.
I don't get it.
Check DJI's Geo Map. "Altitude Zones" aren't types of legally restricted airspace, but are safety zones DJI codes in that typically extend off the runway centerlines from nearby airports. You should see them on the map I linked above in shades of gray.
Dawgpilot Thank you that’s what I needed
To know. I under stand now Thanks again
Get it every time I fly at my favorite location. Don't go above 400 feet...so not an issue. Rarely go above 1 or 200 feet. I also get the confirmation to take responsibility for my flight, and do have to keep an eye on the plane pilots that like to come down and buzz the bay.
Guaro
