Hate!!!!!!!* dji assistant 2 Crashes update at 16% v.01.00.0880
I was afraid of that , I had a really hard time but look up the Post that Zeus.fl posted.
Your going to need to follow that protocol and one thing is you have to TURN OFF THE WIFI on the SC.
That was the ticket for me to ride the SC update to the finish line.
I also posted a video on my SC adventure .
Phantomrain.org
Gear to fly your Air in the Rain and Land on Water.
Phantomrain.org
I had the Wifi off... stange this.
But do you have a sc? so did you ever had problems with rc calibration.?
Compliments of ZEUS>FL hard work and patience.
Make sure you have at least 50% battery
1- Reset the smart controller erasing all data
2- Do not connect it to WiFi
3- Go to settings, Display , Sleep and change to NEVER
4- Download the DJI Assistance 2 for Mavic in this DJI Assistant 2 For Mavic- DJI Download Center- DJI
5- First open the DJI Assistance and then plug the USB C cable to the smart controller
6- When the control ask for the USB configuration select CHARGING
7- Start the update to the last firmware
8- The update will have 3 steps: Download, Transfer and Install the update
9- If everything goes fine at 99% the controller will reboot by it self and once boot you will see a DJI logo with a progress bar installing. This will take few minutes.
10- Once the controller boot again you should be ready to start Pairing the drone.
11- To pair the drone, go to Settings, Aircraft Management and Add the new drone
12- when the wizard indicate and stat beeping to pair the aircraft with the Mavic Air 2 on hold the power bottom for 4 seconds and will start paring.
13- this should complete the process.
Note: if you turn on the WIFI for any reason, the firmware will try to download automatically and will fill the memory and you will have the memory full error. You will have to Reset to factory and try again.
Reactions: pelagic_one
super am gonna try it.
Hiba Drums
