Hello from Bucks County, Pennsylvania
Hello from the Crossroads of America BucksCoBlue.
If you haven't done it yet, you need to take the TRUST test and keep a copy with you when you fly.
It's a free, no fail test that's easy to take that covers the basics of flying a drone.
The mini 3 doesn't need to be registered with the FAA, unless you add stuff to it that will push it past 250 grams or if you pursue the Part 107 certificate that will help the furtherance of as business.
Good luck and welcome to the Forum. :cool:
Welcome to the forum! :)
with my first Mini 3. Very stoked to get started.
As a New Drone Pilot, there are a couple of Legal Things you may need to do…
If you have not already done so, you will need to get your TRUST Certificate. You can get that at the Pilot Institute Web Site (FREE…). Your Drone weighs less than 250-grams (0.55 pounds), and while you are flying under The Exception for Recreational Flyers, you are not required to register your Drone.
FAA TRUST Online Portal for Recreational Drone Operators - Pilot Institute
Get your FAA TRUST Certificate of Completion to legally fly drones for recreational reasons in the United States.
trust.pilotinstitute.com trust.pilotinstitute.com
If you are considering acquiring your Part 107 License, here is a link to get you going…
Since you live in Pennsylvania , there are specific laws and rules for you to follow, please check the link below for all the Rules and Laws that are in effect in your neck of the woods and it also links you to some of the Best Places to Fly in your area… Also, if you travel on vacation, visit friends, and relatives in other parts of the country, check back here so you do not run afoul of the law.
Lift off, 6- feet (2-meters) or so, hover a bit, check the controls (move the drone a bit forward, back, left, right, yaw left and right). By now, your Controller will probably report again, Home point Updated.
Below is the link to all of the downloads offered by DJI for the Mini 3, including the User Manual.
Fly On and Fly Safe…
JefScot
