Hello from Cambridgeshire, UK
Nickyb65
Cambridge, UK
Hi Guys and Girls,
New to the forum and drone flying. Will be about to purchase a DJI Mini 3 Pro setup as I have an interest in land based' photography but want to
try and expand to aerial photography. To me the Mini 3 is perfect, especially for its low weight.
Will post to forum next and hopefully pick your brains on drone questions!
Cheers
Nick
Thumbswayup
Welcome to the forum! :)
Welcome to the forum.
Please and do be sure you have read our guidelines.
Don't be shy and ask anything if you can't find it by searching . Thumbswayup
Welcome from the Hampton Roads area of Virginia, USA. We have a Member's Map in the Upper Right of the Title Bar.
Since you live in the UK, there are specific laws and rules for you to follow, please check to ensure these are current.
Since you are new to drones, here is some Good Old Fashion Advice, and do not be hesitant about "picking our brains," some of us are like Zombies and love to have our Brains Picked…
Here is all the info about the Mini 3, also watch lots of YouTube Videos…
Below is the link to all of the downloads offered by DJI for the Mini 3 Pro, including the User Manual.
Happy, Safe and Legal Droning…
Greetings from Birmingham Alabama, welcome to the forum!
Shanturion
