Hello from Croatia
Hello from the Crossroads of America Josipklemen.
Here's some search results from the site that may help you get started.
Search results for query: fcc mode for mavic air 1
I'm not sure if the "Hacks" still work like they have in the past. DJI keeps upgrading apps that may affect the the modification. 🤔
Good luck and welcome to the Forum. :cool:
Welcome to the forum! :)
Welcome to the forum.
Please and do be sure you have read our guidelines.
Don't be shy and ask anything if you can't find it by searching . Thumbswayup
Greetings from Birmingham Alabama, welcome to the forum!
Reactions: dirkclod
Hi guys from Croatia, new owner of dji mavic air 1.
Here to see if there is any solution to go to FCC mode
Welcome from the Hampton Roads area of Virginia, USA. We have a Member's Map in the Upper Right of the Title Bar.
Since you live in Croatia, there are specific laws and rules for you to follow, please check to ensure these are current.
I do not know anything about how to fool the GPS in your Drone, but…
Even if you may have flown Drones before, here is some Good Old Fashion Advice…
Below is the link to all of the downloads offered by DJI for the Mavic Air, including the User Manual.
Happy, Safe and Legal Droning…
This is actually a great advice, thanks. Cheers 🍻
Reactions: LoudThunder
osje
