Hello from Dallas, TX
Greetings from Birmingham Alabama USA, welcome to the forum!
Welcome to the forum.
Please and do be sure you have read our guidelines.
Don't be shy and ask anything if you can't find it by searching . Thumbswayup
I am new to the community, and also to drone flying. I have a DJI Mini 2, Mini 3 Pro, and a Mavic 3.
As a New Drone Pilot, Even though you are jumping with both feet with the Part 107.
I just passed my Pat 107 Exam a month ago, don't expect your License to show before 6-8 weeks as the TSA performs the background investigation…
In the meantime, here is some Good Old Fashion Advice…
Below is the link to all of the downloads offered by DJI for the Mini 2, including the User Manual.
After you read the Manuals, read them again, you will be surprised what you missed the first time and you will be better prepared for that first "scary moment…"
Happy Droning…
Hello from Dallas, I am new to the community, and also to drone flying. I have a DJI Mini 2, Mini 3 Pro, and a Mavic 3. I am preparing to get my FAA Part 107 certification done this month. Hoping to learn from this community and share my experiences as well!
Welcome to the forum from your Texas neighbor to south!
Welcome to the forum! :)
Happy Droning…
That's a wealth of information, and I will definitely follow your suggestions! Thank you!
Roel Hopstaken
