Hello from Florida's Capital
jonnyweb
FL
I just joined and wanted to be a good boy and post my new member welcome ASAP.
I live with my wife and 3 dogs in the Capital. I have a new drone that i just received this week, it is the Mini 4 Pro. I had a Mavic Air before this but didn't get to fly it nearly as much as I wanted as we moved, moved into a new job, got too busy etc.
I am hopful and going to make it a point to use this drone much more frequently to check out the scenic locations near me and not so near to me so i can capture some great photos and videos to keep and to share.
If anyone has any words of wisdom regarding the Mini 4 Pro please don't hesitate to share them with me.
Thanks for this great forum!
Jonathan
I just joined
"Words are Wisdom" for the Mini 4 Pro has its own Sub-Forum, check it out, you may find things to do with your new baby that you did not dream of…
As a Newly Returning Drone Pilot, there are a couple of Legal Things you may need to do…
If you have not already done so, you will need to get your TRUST Certificate. You can get that at the Pilot Institute Web Site (FREE…). If your Drone weighs less than 250-grams (0.55 pounds), and while you are flying under The Exception for Recreational Flyers, you are not required to register your Drone. That is as long as you do not use the extra large batteries….
FAA TRUST Online Portal for Recreational Drone Operators - Pilot Institute
Get your FAA TRUST Certificate of Completion to legally fly drones for recreational reasons in the United States.
trust.pilotinstitute.com trust.pilotinstitute.com
If you are considering acquiring your Part 107 License, here is a link to get you going…
Since you live in Florida, there are specific laws and rules for you to follow, please check the link below for all the Rules and Laws that are in effect in your neck of the woods and it also links you to some of the Best Places to Fly in your area… Also, if you travel on vacation, visit friends, and relatives in other parts of the country, check back here so you do not run afoul of the law.
Lift off, 6- feet (2-meters) or so, hover a bit, check the controls (move the drone a bit forward, back, left, right, yaw left and right). By now, your Controller will probably report again, Home point Updated.
Below is the link to all of the downloads offered by DJI for the Mini 4 Pro, including the User Manual.
Fly On and Fly Safe…
Tons of great information here, thank you very much for all of the links.
I did the TRUST cert. earlier today, thanks again for that.
I have also watched a ton of videos and i'm sure my wife is sick of seeing me with the youtube channel up on our tv. lol
thanks again for the information and warm welcome!
Welcome to the forum! :)
Jonathan
Welcome to the form.
Claire_missy
