Hello, from Iceland!
Welcome to the forum! :)
Welcome to the forum.
Please and do be sure you have read our guidelines.
Don't be shy and ask anything if you can't find it by searching . Thumbswayup
Welcome to the forum. Iceland is a beautiful place with a lot of epic places to fly a drone!
Greetings from Birmingham Alabama USA, welcome to the forum!
I live in Iceland and if I am lucky I get to fly my drone(Dji Mini 3 Pro).
Since you live in Iceland, there are specific laws and rules for you to follow, please check to ensure these are current.
Even if you may have flown Drones before, here is some Good Old Fashion Advice…
Below is the link to all of the downloads offered by DJI for the Mini 3 Pro, including the User Manual.
Happy Droning…
Hi there pilots, I live in Iceland and if I am lucky I get to fly my drone(Dji Mini 3 Pro). it´s windy here =)
Me and my wife are returning again to Italy and Switzerland next year for 18 days and I really wanted to squeeze some time in Iceland in there but I determined there is just too much to see that it warrants its own special trip. Easily one of the most intriguing and beautiful places in the entire world!
RichardThiery
