Hello from Los Angeles/Bellflower, Ca
Welcome from next door in Bakersfield!
The first thing I will say is GET YOUR TRUST CARD around here the police are trained to ask for it, and even before they want your id they will ask to see your trust card.
secondly USE THIS FORUM- You can get great info for anything drone related from here.
I think by just reading the post on this forum my knowledge has increased tenfold.
For the mini 4 I hear once you put in the extended battery pack you are slightly over the limit BUT Yes- I would register it you only need one number for recreational to fly drones above the limit, so might as well get your number now.
Hello from the Crossroads of America JohnnieGee.
Cafguy has provided some good stuff to consider.
Might as well download the B4UFLY app to help navigate the airspace and apply for permission to fly if permissible (airports,etc.).
Check the local ordinances about drone flights.
Although the FAA governs the AIRSPACE, they don't have control of the property you launch, operate, and land the drone on.
Have fun and welcome to the Forum. :cool:
just recently bought a mini 4 Pro with the extended battery packs. I need to know everything about being legal.
As a New Drone Pilot, there are a couple of Legal Things you may need to do…
If you have not already done so, you will need to get your TRUST Certificate. You can get that at the Pilot Institute Web Site (FREE…). Your Drone with the extended batteries weighs more than 250-grams (0.55 pounds), and even while you are flying under The Exception for Recreational Flyers, you are required to register your Drone.
FAA TRUST Online Portal for Recreational Drone Operators - Pilot Institute
Get your FAA TRUST Certificate of Completion to legally fly drones for recreational reasons in the United States.
trust.pilotinstitute.com trust.pilotinstitute.com
If you are considering acquiring your Part 107 License, here is a link to get you going…
Since you live in California, there are specific laws and rules for you to follow, please check the link below for all the Rules and Laws that are in effect in your neck of the woods and it also links you to some of the Best Places to Fly in your area… Also, if you travel on vacation, visit friends, and relatives in other parts of the country, check back here so you do not run afoul of the law.
Lift off, 6- feet (2-meters) or so, hover a bit, check the controls (move the drone a bit forward, back, left, right, yaw left and right). By now, your Controller will probably report again, Home point Updated.
Below is the link to all of the downloads offered by DJI for the Mini 4 Pro, including the User Manual.
Fly On and Fly Safe…
Welcome, I’m an experienced pilot in Long Beach just south of Bellflower. I know the area and a great “learn to fly” area in El Dorado park with an annual pass. I would be glad to talk to you and perhaps meet up for some instruction. I Will send you my phone number for contact. Check for my message.
Doug McConnell
Doug McConnell
Perfect, I would love that
Reactions: LoudThunder
Your reply helped immensely… thank you so much for taking the time.
Welcome to the forum! :)
dvkhamtruocsinh
