Hello from Melbourne
Hi everyone. Just got me new Air 3 and was looking for recommended locations to get some good footage in Victoria.
You wrote, "yet to discover the landscape here." I've read that the entrance to Port Phillip is murder to get through "The Rip…" And take the Great Ocean Road to see the "Towers…" Might make for some interesting videos…
Since you live in Australia, there are specific laws and rules for you to follow, please check to ensure these are current.
Plug in your phone/tablet into your controller; turn on the Controller and DJI Fly App (if it does not start on its own…). On the Drone, open the front legs, then open the back legs, and then remove the Gimbal Cover.
Lift off, 6 feet (2-meters) or so, hover a bit, check the controls (move the drone a bit forward, back, left, right, yaw left and right). By now, your Controller will probably report again, "Home point Updated."
Below is the link to all of the downloads offered by DJI for the Mavic Air 3, including the User Manual.
Fly On and Fly Safe…
Thank you so much. I used to fly the original Air for 3yrs, but still picked up a couple of important tips that used to overlook. I am still finding my way around the forum, so the members map was a good tip. Will look into it and find someone who can provide me more local info. Thanks again
Reactions: LoudThunder
Welcome to the forum! :)
Well, thank you for the kind reply, here is another Tip. We have a Sub-Forum, Local and Regional Discussion and in there is a Sub-Sub-Forum for Australia, Have yourself a look and do not be shy about PMing a member who has posted there…
Australia
Reactions: raptorclaw
Australia
Yes. Did that and received a reply too. I like how friendly everyone is here
JefScot
