Hello from Northern California
Brandon_cal
Northern California
Got the Mini 2 back in December (previously had the Tello drone). Frustrated with the amount of places I'm not allowed to fly for working through it. Almost put it in a lake on my second flight when i was racing across the water and pulled "back" on the stick like it was an aircraft. Video of the incident on YouTube under 530Drone. I fly for the photography aspect.
Welcome to the forum!
Greetings from Birmingham Alabama, welcome to the forum!
Welcome to the forum.
Don't be shy and ask anything if you can't find it by searching . Thumbswayup
Welcome from the Hampton Roads area of Virginia, USA. I fly a Mini 2 also.
We have a Member's Map in the Upper Right of the Title Bar, Tap "Members", Tap "Member's Map" Members map
Since you live in California, there are a couple of Legal Things you may need to do…
You will need to get your TRUST Certificate. You can get that at the Pilot Institute Web Site (FREE…) . If your Drone weighs less than 250-grams (0.55 pounds) and you are flying under The Exception for Recreational Flyers, you are not required to register your Drone. I registered my Mini 2 because the TRUST Certificate and FAA Registration established me as a "certified" Unmanned Aerial Vehicle (UAV) Flyer.
Link to the Pilot Institute Web Site (FREE…) FAA TRUST Online Portal for Recreational Drone Operators - Pilot Institute
Link to the FAADroneZone (Optional for Drones under 250-Grams…) FAADroneZone
I live between an Air Force Base and a Commercial Airport, then just beyond that is an Army Post, and there are lots, did I say LOTS of national Parks with Big Fat No Fly Zones… So, it could be worse…
Below is the link to all of the downloads offered by DJI for the Mini 2. You will also find the 75-page User's Manual, in case your Drone did not come with one.
DJI Mini 2 - Download Center - DJI
Happy and Safe Droning…
Welcome to the forum! Where in 530/NorCal are you located? I'm in Yreka, in the middle of the State of Jefferson.
Welcome to the forum! :)
Phly858
