Just checking in! Looking forward learning more about my new Mini SE and developing some new skills.
Welcome to the form, from Tampa FLJust checking in! Looking forward learning more about my new Mini SE and developing some new skills.
Welcome to the forum from the windy Colorado Rockies! Happy and safe flying!Just checking in! Looking forward learning more about my new Mini SE and developing some new skills.
Great post! Thank you for the info, time and effort for providing this.Welcome from the Hampton Roads area of Virginia, USA. We have a Member's Map in the Upper Right of the Title Bar. Click on "Members" and then Click on "Member's Map…" Check it out and you might find some new flying friends.
Member Map
mavicpilots.com
As a New Drone Pilot, there are a couple of Legal Things you may need to do…
If you have not already done so, you will need to get your TRUST Certificate. You can get that at the Pilot Institute Web Site (FREE…) . If your Drone weighs less than 250-grams (0.55 pounds) and you are flying under The Exception for Recreational Flyers, you are not required to register your Drone.
When I first started flying I registered my Mini 2 because the TRUST Certificate and FAA Registration established me as a "certified" Unmanned Aerial Vehicle (UAV) Pilot. I have now passed my Part 107 License Exam and am awaiting the arrival of my Permanent License and then I will re-register my Mini 2 under Part 107.
FAA TRUST Online Portal for Recreational Drone Operators - Pilot Institute
Get your FAA TRUST Certificate of Completion to legally fly drones for recreational reasons in the United States.trust.pilotinstitute.com
FAADroneZone
faadronezone.faa.gov
If you are considering acquiring your Part 107 License, here is a link to get you going…
Online Ground School: Aviation Classes - Pilot Institute
Pilot Institute offers courses on drones and airplanes from world-class experts. Pass the Part 107 or Private Pilot exam and take to the skies.pilotinstitute.com
Since you live in Florida, there are specific laws and rules for you to follow, please check the link below for all the Rules and Laws that are in effect in your neck of the woods and it also links you to some of the Best Places to Fly in your area… Also, if you travel on vacation, visit friends, and relatives in other parts of the country, check back here so you do not run afoul of the law.
Drone Laws and Best Places to Fly in Every US State - Pilot Institute
pilotinstitute.com
Below is the link to all of the downloads offered by DJI for the Mini SE, including the User Manual.
DJI Mini SE - Download Center - DJI
Learn and download DJI Mini SE related apps, software, and manuals at the DJI Download Centerwww.dji.com
Happy Droning…
