Hello from NYC
cletus1
new york
Got my license earlier this year - our company does digital twins using photogrammetry.
I have an Air 2S that I've only crashed a few times lol
One crash I was able to re-solder a new arm to it as I had cracked the arm at the motor mount. She may not look like much, but she's got it where it counts!
Cheers everyone!
You wrote that you are licensed, but does that mean you have your TRUST or part 107 Certification, so there might be a couple of Legal Things you may need to do…
If you have not already done so, you will need to get your TRUST Certificate. You can get that at the Pilot Institute Web Site (FREE…). Your Drone weighs more than 250-grams (0.55 pounds), and even while you are flying under The Exception for Recreational Flyers, you are required to register your Drone.
If you do not have your Part 107 License, here is a link to get you going…
Since you live in New York, there are specific laws and rules for you to follow, please check the link below for all the Rules and Laws that are in effect in your neck of the woods and it also links you to some of the Best Places to Fly in your area… Also, if you travel on vacation, visit friends, and relatives in other parts of the country, check back here so you do not run afoul of the law.
Since you have "Crashed a Few Times, here is some Good Old Fashion Advice…
Lift off, 6- feet (2-meters) or so, hover a bit, check the controls (move the drone a bit forward, back, left, right, yaw left and right). By now, your Controller will probably report again, Home point Updated.
Below is the link to all of the downloads offered by DJI for the Air 2S, including the User Manual.
Fly On and Fly Safe…
chrisjohnson0
