Hello from RI - Rhode Island not Long Island :)
Greetings welcome to the forum!
Welcome to the forum! :)
I picked up a Mavic Mini to see if I would be into it and I’m obsessed
Here are some things to help you get started with your Mavic Mini:
  • The current Mavic Mini manual can be downloaded here (it doesn't come in the box). Other important documents can be found on the Mavic Mini downloads page.
  • Check out this getting started guide for some tips not found in the Mavic Mini manual.
  • Your drone batteries will last longer if you use and maintain them like this.
  • Practice flying outdoors in a wide open location that's free of all obstacles. Don't attempt to fly inside your house or in other confined locations.
  • The drone records flight data each time you fly. You can decrypt and view those flight logs with these tools.
  • Check out MavicHelp.com for commonly used accessories you might need.
Welcome to the forum.
Don't be shy and ask anything if you can't find it by searching .Thumbswayup
Welcome to the forum from Chicago the Windy City.
How do you like the Mini?
Thanks for the welcome! The Mini has been great so far. I was debating if I should have gotten the Mini 2 but for the money the original Mini seemed acceptable. The one thing I noticed is when around more trees there is interference and lag. I’ll have to look into that some more.
One big difference is the transmission connection is better on the MM2.
The Ocusync is 2.0 on the MM2. My MP's have 2.4 ghz.
The Phantom 4 pro has Duel band 2.4 ghz Ocusync. Still much better.
You can check it out yourself, do a query on the upper right hand corner
glass. Just type in Ocusync, for MM1, see what the answers are.
Wesleydjimavic2pro
