Hello from Rockland County NY
Welcome to the forum.
Please and do be sure you have read our guidelines.
Don't be shy and ask anything if you can't find it by searching . Thumbswayup
My goal is to become a professional pilot and make passive income with my skills.
As a New Drone Pilot, there are a couple of Legal Things you may need to do…
You wrote, "My goal is to become a professional pilot and make passive income with my skills." To achieve this, in part, you will need to get your Part 107 License, a Link to help you achieve this is below. The next part is not possible flying a drone… The IRS defines "Passive Income" as income that can come from two sources: rental property or a business in which one does not actively participate, such as being paid book royalties or stock dividends. So, unless you intend to Rent You drone, or write a book about your drone ("The Little Drone That Could" ) or sell stock in your drone and hope others will buy a share, you are not going to see any Passive Income… But if you get your Part 107 License and someone pays you for flying it, then you will received Earned Income, But, then you will be self-employed and responsible for the whole share or your Social Security/Medicare taxes…
Inquirimg Mind Want to Know…
If you have not already done so, you will need to get your TRUST Certificate. You can get that at the Pilot Institute Web Site (FREE…) . Your Drone weighs less than 250-grams (0.55 pounds) and if you are flying under The Exception for Recreational Flyers, you are not required to register your Drone.
When I first started flying I registered my Mini 2 because the TRUST Certificate and FAA Registration established me as a "certified" Unmanned Aerial Vehicle (UAV) Pilot. I have now passed my Part 107 License Exam and am awaiting the arrival of my Permanent License and then I will re-register my Mini 2 under Part 107.
If you are considering acquiring your Part 107 License, here is a link to get you going…
Since you live in New York, there are specific laws and rules for you to follow, please check the link below for all the Rules and Laws that are in effect in your neck of the woods and it also links you to some of the Best Places to Fly in your area… Also, if you travel on vacation, visit friends, and relatives in other parts of the country, check back here so you do not run afoul of the law.
Below is the link to all of the downloads offered by DJI for the Mini 2, including the User Manual.
Happy Droning and Happy New Year!
Welcome to the forum! :)
Here are some things to help you get started with your drone:
  • Download the DJI manual for your drone here (it doesn't come in the box). The manual is packed with lots of useful tips and will give you a better understanding of your drone's features.
  • Check out this getting started guide for some tips not found in the DJI manual.
  • Your drone batteries will last longer if you use and maintain them like this.
  • Practice flying outdoors in a wide open location that's free of all obstacles. Don't attempt to fly inside your house or in other confined locations.
  • The drone records flight data each time you fly. You can decrypt and view those flight logs with these tools.
  • Check out MavicHelp.com for commonly used accessories you might need.
faridudinmuhammad
