Hello from So. California, USA
Welcome to the forum.
Don't be shy and ask anything if you can't find it by searching .Thumbswayup
Hi PapaFixit Welcome to Mavic Pilots.
New flyer advice,
Wide open space.
Slow & easy
Power-lines & trees are evil.
Don't expect RTH (Return To Home) to save you especially if you are under trees.
Don't forget to read the manual ;)
Download Mini manual HERE
You want an SD card that is U3 for 4K
Most of all have FUN
Welcome from Southern California, West Los Angeles Area
Welcome to the forum! :)
First time drone user. Using a Mavic Mini.
Here are some things to help you get started with your Mavic Mini:
  • The current Mavic Mini manual can be downloaded here (it doesn't come in the box). Other important documents can be found on the Mavic Mini downloads page.
  • Check out this getting started guide for some tips not found in the Mavic Mini manual.
  • Your drone batteries will last longer if you use and maintain them like this.
  • Practice flying outdoors in a wide open location that's free of all obstacles. Don't attempt to fly inside your house or in other confined locations.
  • The drone records flight data each time you fly. You can decrypt and view those flight logs with these tools.
  • Check out MavicHelp.com for commonly used accessories you might need.
sscott062
