Hello from Colorado, USA
Greetings from Birmingham Alabama USA: welcome to the forum! We look forward to hearing from you!
I'm a Wildlife and landscape photographer and newbie to Mavic world.
If you are a New Drone Pilot, there are a couple of Legal Things you may need to do…
First, if you have not already done so and you want to fly your drone recreationally, you will need to get your TRUST Certificate. You can get that at the Pilot Institute Web Site (FREE…). This Link is to the Pilot Institute Web Site where you can get your TRUST Certificate. (FREE…)
Next, if your Drone weighs less than 250-grams (0.55 pounds), and while you are flying under the 44809 Exception for Recreational Flyers, you are not required to register your Drone.
However, if your Drone weighs more than 250-grams (0.55 pounds), and even while you are flying under The Exception for Recreational Flyers, you are required to register your Drone. This link is to the FAADroneZone where you can register your Drone. The cost is $5.00…
If you are considering acquiring your Part 107 License, here is a link to get you going…
Since you live in Colorado, there are specific laws and rules for you to follow, please check the link below for all the Rules and Laws that are in effect in your neck of the woods and it also links you to some of the Best Places to Fly in your area… Also, if you travel on vacation, visit friends, and relatives in other parts of the country, check back here so you do not run afoul of the law.
Lift off, 6- feet (2-meters) or so, hover a bit, check the controls (move the drone a bit forward, back, left, right, yaw left and right). By now, your Controller will probably report again, Home point Updated.
Fly On and Fly Safe…
Welcome to the forum @bitse! :)
Really appreciate for taking time to share the details. I will go through every items prior to takeoff. So far i was been with my buddy while he use for Drone Shots
@bitse,
You accidentally, signed on to the best forum structure ever. I wish other forums used this same layout.
To me, here, It's like part of my friends, family?
The mods keep it real!
I almost forgot :rolleyes:
Welcome to the forum.👌
Rod ..
Welcome to the forum. We look forward to your participation and your view of the world.
ProFoto
