Hello from Tennessee
Hello!
Still learning about the drone part of things, but pretty handy with the radio and electronics end. Live near Knoxville (East TN).
Just looking for a place to talk about things that they don't like discussed on the DJI forum.
Thanks!
(PS - not really comfortable with the term 'pilot')
A big welcome to the forum from the UK!
Such a beautiful part of the USA
Greetings from Birmingham Alabama
Hello!
Thanks!
Cool avatar...is that a selfie?
quietly self-reflecting after a massive rampage.
I understand, I would have gone on a Rampage too... L :rolleyes: L . . .
Seriously now, perhaps the bear spent too much time at "Oak Ridge…"
As a New Drone Pilot, there are a couple of Legal Things you may need to do…
If you have not already done so, you will need to get your TRUST Certificate. You can get that at the Pilot Institute Web Site (FREE…). Your Drone weighs less than 250-grams (0.55 pounds), and while you are flying under The Exception for Recreational Flyers, you are not required to register your Drone. IF your Drone weighs more than 250-grams (0.55 pounds), and even while you are flying under The Exception for Recreational Flyers, you are required to register your Drone.
If you are considering acquiring your Part 107 License, here is a link to get you going…
Since you live in Tennessee, there are specific laws and rules for you to follow, please check the link below for all the Rules and Laws that are in effect in your neck of the woods and it also links you to some of the Best Places to Fly in your area… Also, if you travel on vacation, visit friends, and relatives in other parts of the country, check back here so you do not run afoul of the law.
Lift off, 6- feet (2-meters) or so, hover a bit, check the controls (move the drone a bit forward, back, left, right, yaw left and right). By now, your Controller will probably report again, Home point Updated.
Fly On and Fly Safe…
PNW_Aerials
