Hello from the Sunshine State
Shelp
Florida
Just checking in. Being a professional photographer and a Travel agency owner, I thought it would be a great idea to use a mavic Mini to add some unique photos to our ads. It's a great little drone and adds a challenge to my work and a ton of satisfaction. It's nice to be part of a creative and fun loving group of folks.
Hello from the Crossroads of America Shelp.
You need to take the TRUST test and keep a copy with you when you fly.
It's a free no fail test that's easy to take that covers the basics of flying a drone.
Even though the Mini is a sub 250 gram drone, it should be registered with the FAA if it's going to be used for your business.
You'll also need a Part 107 certificate to do it legally for your business.
More information here.
Good luck and welcome to the Forum. :cool:
Welcome to the forum @Shelp! :)
First off, you need to know that if you do not have your Part 107 License, you cannot take and use the photos in your business, legally anyway… you may be doing it, but it's like driving at a 100 MPH on the highway, you can do it, but it ain't legal…
As a New Drone Pilot, there are a couple of Legal Things you may need to do…
If you have not already done so, you will need to get your TRUST Certificate. You can get that at the Pilot Institute Web Site (FREE…). Your Drone weighs less than 250-grams (0.55 pounds), and while you are flying under The Exception for Recreational Flyers, you are not required to register your Drone.
FAA TRUST Online Portal for Recreational Drone Operators - Pilot Institute
Get your FAA TRUST Certificate of Completion to legally fly drones for recreational reasons in the United States.
trust.pilotinstitute.com trust.pilotinstitute.com
If you are considering acquiring your Part 107 License, here is a link to get you going…
Since you live in Florida, there are specific laws and rules for you to follow, please check the link below for all the Rules and Laws that are in effect in your neck of the woods and it also links you to some of the Best Places to Fly in your area… Also, if you travel on vacation, visit friends, and relatives in other parts of the country, check back here so you do not run afoul of the law.
Lift off, 6- feet (2-meters) or so, hover a bit, check the controls (move the drone a bit forward, back, left, right, yaw left and right). By now, your Controller will probably report again, Home point Updated.
Below is the link to all of the downloads offered by DJI for the Mini, including the User Manual.
Fly On and Fly Safe…
Dispatcher
