Welcome from the Hampton Roads area of Virginia, USA. We have a Member's Map in the Upper Right of the Title Bar.
mavicpilots.com
you have already been given the head-up on your legal requirements, but since you live in Texas, there are specific laws and rules for you to follow, please check to ensure these are current.
Drones are allowed in Texas for recreational and commercial use, subject to FAA and local regulations. Read on for details.
drone-laws.com
You might also want to check out this latest posting on our Forum…
March 29, 2022 - A federal judge overturned the state of Texas’ stringent drone restrictions today, holding that it was an unconstitutional violation of the First Amendment. https://nppa.org/sites/default/files/NPPA%20vs%20McCraw.pdf...
mavicpilots.com
Now, for some Good Old Fashion Advice…
Below is the link to all of the downloads offered by DJI for the
Mini 3 Pro, including the User Manual.
Learn and download DJI
Mini 3 Pro related apps, software, and manuals at the DJI Download Center
www.dji.com
Happy, Safe and Legal Droning…
