Welcome from the Hampton Roads area of Virginia, USA. We have a Member's Map in the Upper Right of the Title Bar.
mavicpilots.com
First off as SethB told you and I'm telling you it too; the
Mini 2 is a less than 250 Grams. Actually, mine weights exactly 238.5 grams... The Average weight of an ND Filter is less than a Gram; most weigh 0.75 to 0.85 Grams. To get a grasp of a gram, a Penny (1-cent coin) weighs 2.5 Grams. Go ahead, pick up 4-pennies, that's 10-grams... If you taped these onto your
Mini 2, it would still weigh less than 250 Grams. So, unless you are going to put a saddlebag onto your drone to carry all the spare ND Filters, you have nothing to worry about…
Ok, moving on… In your part of the country Washington State, there are a couple of Legal Things you may need to do…
If you have not already done so, you will need to get your TRUST Certificate. You can get that at the Pilot Institute Web Site (FREE…) . If your Drone weighs less than 250-grams (0.55 pounds) and you are flying under The Exception for Recreational Flyers, you are not required to register your Drone.
I registered my
Mini 2 because the TRUST Certificate and FAA Registration established me as a "certified" Unmanned Aerial Vehicle (UAV) Flyer.
Link to the Pilot Institute Web Site (FREE…)
Get your FAA TRUST Certificate of Completion to legally fly drones for recreational reasons in the United States.
trust.pilotinstitute.com
Link to the FAADroneZone (Optional for Drones under 250-Grams…)
faadronezone.faa.gov
Since you live in Washington, there are specific laws and rules for you to follow, please check to ensure these are current.
Drones are allowed in the State of Washington for recreational and commercial use, subject to FAA and local regulations. Read on for details.
drone-laws.com
Below is the link to all of the downloads offered by DJI for the
Mini 2, including the User Manual.
Learn and download
DJI Mini 2 related apps, software, and manuals at the DJI Download Center
www.dji.com
Happy, Safe and Legal Droning…
