Hello from West Linn, OR
SalmonJefe
West Linn, Oregon
Hello, I'm a semi-retired furniture maker, but my first career was in video. I witnessed the transition from SD to HD, 4:3 to 16:9, linear to non-linear editing, Tape to hard drives, etc. Some of that probably means nothing to some of you. I got out when it was clear that younger guys were willing to work twice as long for half the money. I have not edited a single video since and have no desire to re-enter that arena. Living like a mushroom is not a lifestyle.
That being said, I've always been into still photography and so I purchased a Mini 3 Pro to see what I can from the air. I have a trip planned to Vancouver Island in September. I have some questions regarding flying in BC, but I'll post those elsewhere.
I'm glad to see this community exists, looking forward to the drone experience.
Jeff
Hello Neighbor!
From Hood River. :)
I have done some VHS tapes to get them on the internet lately (SD).
Really what concerns me, your taking this on a trip next month?
If you don't have any experience with these flying things.
I great day goes really bad fast. :rolleyes:
Anyways, this forum is !
Others will give info about the BC.
Curious, how long you have lived in this area, I got something, I found on a VHS tape you might like. I posted it on You-tube, no reason to share it here.
BTW, Welcome to the Forum!
Rod ..
Welcome to the forum! :)
As a New Drone Pilot, there are a couple of Legal Things you may need to do…
If you have not already done so, you will need to get your TRUST Certificate. You can get that at the Pilot Institute Web Site (FREE…) . If your Drone weighs less than 250-grams (0.55 pounds) with the small batteries and while you are flying under The Exception for Recreational Flyers, you are not required to register your Drone. But if you put the large batteries in, then you need to register it…
When I first started flying I registered my Mini 2 because the TRUST Certificate and FAA Registration established me as a "certified" Unmanned Aerial Vehicle (UAV) Pilot.
If you are considering acquiring your Part 107 License, here is a link to get you going…
Since you live in Oregon, there are specific laws and rules for you to follow, please check the link below for all the Rules and Laws that are in effect in your neck of the woods and it also links you to some of the Best Places to Fly in your area… Also, if you travel on vacation, visit friends, and relatives in other parts of the country, check back here so you do not run afoul of the law.
Lift off, 6- feet (2-meters) or so, hover a bit, check the controls (move the drone a bit forward, back, left, right, yaw left and right). By now, your Controller will probably report again, Home point Updated.
Below is the link to all of the downloads offered by DJI for the Mini 3 Pro, including the User Manual.
Fly On and Fly Safe…
I did not want this getting lost in the above long topic I wrote… Since you are interested in taking your drone to Canada, you need to obey their laws…
So here is a link to get you started…
Fly Safe…
Jeff
Welcome Jeff aka SalmonJefe!
I’m just up the road from you in West Slope. We’ve had a lot of parallels in pro video experience, my parachute was a transition to teaching college courses in video, sound, multimedia, vr, etc. And drone videography!
Congrats on your semi retirement, working with wood is good.
Jeff: Welcome to the forum from Chicago the Windy City.
FLY SAFE & FLY SMART ALSO FLY LEGALLY
And, somebody mentioned about taking a trip and not having any experience, it's like taking a new camera on a trip for the first time. Agree, that a great day, goes really bad fast. Practice, and more practice before you leave for your trip. Especially flying around water.
Flying S
