Hello from Wigan. (UK)
Greetings from New Zealand! I think you're also from the forum DJI Pilots?
Greetings from Wigan
Since you live in the UK, there are specific laws and rules for you to follow, please check to ensure these are current.
Plug in your phone/tablet into your controller; turn on the Controller and DJI Fly App (if it does not start on its own…). On the Drone, open the front legs, then open the back legs, and then remove the Gimbal Cover.
Lift off, 6 feet (2-meters) or so, hover a bit, check the controls (move the drone a bit forward, back, left, right, yaw left and right). By now, your Controller will probably report again, "Home point Updated."
Below is the link to all of the downloads offered by DJI for the Mini 4 Pro, including the User Manual.
Fly On and Fly Safe…
Welcome to the forum from the beautiful woods of Maine,USA!
There’s many knowledgeable members here who are willing to help you with any questions you might have. Search the forums using keywords and if you don’t find an answer, post your questions and I’m sure you’ll get a quick response!
Fly safe, enjoy and stay safe!
kmart
